- June 26, 2019 at 13:19 #19962
Fabian Fassbind
ParticipantPosts: 1Threads: 0Joined: Jun 2019Hello,
when i open Materials with linked Textures in Project Manager, 3DS Max Crashes.
Materials without correct linked Textures work Fine. The Materials are from Arroway and the Textures relatively large PNGs.
Plugin version: 2.96.02
3ds Max version: 3ds Max 2020.1 Update
Renderer: Corona 4 - June 26, 2019 at 13:20 #19967
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Please generate the bug report.
(menu “Project Manager” ==>> Create support Request) and attach the material library with textures.Thanks for your feedback.
- June 26, 2019 at 13:37 #19971
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Also you can try update to Corona Renderer 4 (hotfix 1) .
This version fixes a bug related to rendering. Maybe this also fixes a bug appears then rendering materials.
- June 27, 2019 at 12:32 #19983
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Thanks for your examples of material libraries!
Thanks to you I reproduced the error and find a solution.
Hotfix will be released on next week. - July 1, 2019 at 12:34 #20008
ModeratorPosts: 264Threads: 1283Joined: Aug 2009This issue is fixed in version 2.96.23
You can download latest version from dashboard.
Auto-updater will be triggered in few days if there’s no critical issue found.
