- May 28, 2021 at 12:15 #32202
Robert Ecker
ParticipantPosts: 1Threads: 1Joined: Apr 2021Hi!
I’ve got a issue here with “old” scenes, created before using PM. Whenever i try to open those scenes Max ( 2019 & VRAY 5 ) is crashing.
The Scene Converter Dialog or the missing Textures Dialog is always showing up briefly before the crash – that’s pretty wierd because none of the used texture-files were moved/deleted etc.
So is it possible that PM is performing some tasks ( i.e. searching for these textures ) on Max start-up that can cause the crash ?
Thanks in advance
Plugin version: latest
3ds Max version: 2019
Renderer: vray 5 - May 28, 2021 at 12:16 #32204
ModeratorPosts: 263Threads: 1210Joined: Aug 2009This issue doesn’t relate to Project Manager
- May 28, 2021 at 12:22 #32206
Robert Ecker
ParticipantPosts: 1Threads: 1Joined: Apr 2021Thank’s for the quick answer. But it’s strange – that issue appears since using PM, and “old” scenes means 1 month old
- May 28, 2021 at 13:15 #32208
ModeratorPosts: 263Threads: 1210Joined: Aug 2009Try to check your scenes using 3ds Max Security Tools
https://apps.autodesk.com/3DSMAX/en/Detail/Index?id=7342616782204846316
