- January 13, 2021 at 17:10 #30804
KARIM HASSAYOUNE
ParticipantPosts: 3Threads: 5Joined: Sep 2014- Double clicking an asset -> does not work
- Right-click >merge with default 3ds max dialog -> does not work
- Right-click >Open with associated program -> does not work
Hello,
So today I launched Project Manager as usual, tried to insert some models from my library but it does not work anymore :
I do not get any error message. When I try to merge an object, nothing happens at all.
The only option that still works is merge as XRef scene.
I tried deinstalling and reinstalling Project Manager but the issue is not solved.
I’m using version : 3.13.24
3ds max 2021.3
Plugin version: 3.13.24
3ds Max version: 2021.3
Renderer: Vray - January 13, 2021 at 17:10 #30806
Please generate the bug report.
- January 13, 2021 at 20:12 #30809
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Please check version 3.13.29
This bug is resolved.
