- December 26, 2011 at 20:49 #9616
Borubar
GuestPosts: 13Threads: 20Joined:Hi,
I try to use Project Manager on 3DS Max Design 2012 x64 SAP.
The script has been installed properly but whenever I try to open PM the following error persists (this is from the Listener window):
— Error occurred in anonymous codeblock; filename: C:\Users\Borubar\AppData\Local\Autodesk\3dsMaxDesign2012 – 64bit\enu\scripts\TrackScripts\ProjectManager\PM.mse; position: 65527; line: 247
— Defined in encrypted script
— Error occurred during fileIn in #C:\Users\Borubar\AppData\Local\Autodesk\3dsMaxDesign2012 – 64bit\enu\scripts\TrackScripts\ProjectManagerPM.mse; line number: 247
— called in execute(); filename: C:\Users\Borubar\AppData\Local\Autodesk\3dsMaxDesign2012 – 64bit\enu\scripts\TrackScripts\ProjectManagerPM.mse; position: 737; line: 3
— called in anonymous codeblock
— Frame:
>> MAXScript MacroScript Error Exception:
— Cannot assign to read-only variable: HighLight <<Please notice I have .Net already installed (my Windows 7 x64 system is fully updated).
- December 27, 2011 at 03:02 #9617
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Thanks for bug-report.
I hope your problem is solved.
Please download the latest version Download
If problem is not solved please generate the bug report (menu “Project manager” ==>> Create support Request)
Regards
Alex Kramer
- December 29, 2011 at 23:19 #9618
Borubar
GuestPosts: 13Threads: 20Joined:Problem solved, indeed – congratulations and thank you!
