Viewing 8 posts
  • #37018
    Allaz Antoine
    Threads: 4
      Hello,
      I try to have the same library on 2 computers. I copy the settings folder from one to other but it doesn’t work. Have you any Idea ? I don’t want to use the database. There is not a simple way to copy just the files from a computer to an other and have the same Catalogs, Categories etc ?
      Thank you !
      Antoine
    Plugin version: 3
  • #37021
    Threads: 1241
  • #37022
    Allaz Antoine
    Threads: 4
      Thank you for your response. Shure but i’m look for something faster and automatic, I want to use a backup application and then restor the folder on my second computer.
      There isn’t files containing the categories and all these suffs ?
  • #37023
    Threads: 1241
      Database stored in the file ProjectManager_3.db
      By default, it located by the path “%localappdata%/Autodesk/3dsMax/<3ds max version>- 64bit/ENU/scripts/Kstudio/ProjectManager_3/Settings/”
  • #37024
    Allaz Antoine
    Threads: 4
      It’s there maybe the problem, I backup the settings folder including ProjectManager_3.db but It doesn’t change nothing. Have you any idea ? I didn’t change the preference and anythings.
      Thanks for your help
  • #37026
    Threads: 1241
      Don’t miss importing settings to a new location.
      Close Project Manager before and include ProjectManager_3.db to importing
  • #37027
    Allaz Antoine
    Threads: 4
      I try to export/import settings with project manager and it doesn’t change nothing.
      I try do delete Settings and temp folders from computer 2 and paste folders from computer 1 and it doesn’t change.
      The only way I found is to import from preferences/database/restore database and there it change.
      The ProjectManager_3.db from Settings folder look like unchanged from the 1st installation (172ko 11.04.22)
  • #37076
    Allaz Antoine
    Threads: 4
      Hello,
      At the end i’ve found a solution. I backup the AppData\Local\Kstudio data cache and it works !
Viewing 8 posts
