- October 16, 2022 at 15:24 #37018
Allaz Antoine
ParticipantPosts: 1Threads: 4Joined: Dec 2021Hello,
I try to have the same library on 2 computers. I copy the settings folder from one to other but it doesn’t work. Have you any Idea ? I don’t want to use the database. There is not a simple way to copy just the files from a computer to an other and have the same Catalogs, Categories etc ?
Thank you !
Antoine
Plugin version: 3
- October 16, 2022 at 15:24 #37021
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Just use the tool “Export/Import Settings”
- October 16, 2022 at 17:09 #37022
Allaz Antoine
ParticipantPosts: 1Threads: 4Joined: Dec 2021Thank you for your response. Shure but i’m look for something faster and automatic, I want to use a backup application and then restor the folder on my second computer.
There isn’t files containing the categories and all these suffs ?
- October 16, 2022 at 17:16 #37023
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Database stored in the file ProjectManager_3.db
By default, it located by the path “%localappdata%/Autodesk/3dsMax/<3ds max version>- 64bit/ENU/scripts/Kstudio/ProjectManager_3/Settings/”
- October 16, 2022 at 17:59 #37024
Allaz Antoine
ParticipantPosts: 1Threads: 4Joined: Dec 2021It’s there maybe the problem, I backup the settings folder including ProjectManager_3.db but It doesn’t change nothing. Have you any idea ? I didn’t change the preference and anythings.
Thanks for your help
- October 16, 2022 at 23:45 #37026
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Don’t miss importing settings to a new location.
Close Project Manager before and include ProjectManager_3.db to importing
- October 17, 2022 at 10:09 #37027
Allaz Antoine
ParticipantPosts: 1Threads: 4Joined: Dec 2021I try to export/import settings with project manager and it doesn’t change nothing.
I try do delete Settings and temp folders from computer 2 and paste folders from computer 1 and it doesn’t change.
The only way I found is to import from preferences/database/restore database and there it change.
The ProjectManager_3.db from Settings folder look like unchanged from the 1st installation (172ko 11.04.22)
- October 24, 2022 at 10:16 #37076
Allaz Antoine
At the end i’ve found a solution. I backup the AppData\Local\Kstudio data cache and it works !
