- September 15, 2023 at 14:27 #39769
Rossen Mitov
ParticipantPosts: 10Threads: 9Joined: Jan 2015As the title says, I am getting an application Error at 3ds Max startup after installing Project Manager 3.23.36. I can’t do anything in 3ds Max except so I have to forcefully end the 3dsmax.exe process from the Task Manager. The only way to fix it was to uninstall Project Manger. Please see the screenshot below.
Plugin version: 3.23.36
3ds Max version: 3ds Max 2023.3.3
Renderer: V-Ray 6 Update 1.2 - September 15, 2023 at 14:30 #39774
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Try the next:
Install/reinstall the latest Updates and Service Packs for 3Ds Max
Delete file “Kstudio-CacheStart.ms” from the directory
%localappdata%\Autodesk\3dsMax\2023 – 64bit\ENU\scripts\startup - September 15, 2023 at 14:49 #39775
Rossen Mitov
ParticipantPosts: 10Threads: 9Joined: Jan 2015I will try this out when I have some free time. Thanks! I managed to restore the previous version of the plug-in (3.18.68) and everything works fine for now. I will write back once I try your suggestion and report the results.
