- February 27, 2018 at 22:20 #14857
gomeztsf
ParticipantPosts: 1Threads: 7Joined: Feb 2018Hi I cant seem to add my unc paths, we cant use relative paths, because every user could have setup the disks differently and will cause problems when network rendering, anyone.
would really appreciate your help
Thanks!
Plugin version: 2.5
- February 27, 2018 at 22:24 #14860
ModeratorPosts: 263Threads: 1227Joined: Aug 2009You can use the mapped drives as solution.
- February 27, 2018 at 22:31 #14861
gomeztsf
ParticipantPosts: 1Threads: 7Joined: Feb 2018that´s exactly what i dont want to use hehe, i need them to be like this \\powervault\libraries
- February 27, 2018 at 22:36 #14862
ModeratorPosts: 263Threads: 1227Joined: Aug 2009Network paths is always supported.
“Relative” and “network” it’s a different notions.
You can use network or mapped paths – any what is more comfortably for you.
- February 27, 2018 at 22:41 #14863
gomeztsf
ParticipantPosts: 1Threads: 7Joined: Feb 2018thanks Kramer, but when I try to add the path for the network folder, it doesn´t work, and it doesn´t appear as an option in the dropdown menu
- February 27, 2018 at 22:44 #14864
ModeratorPosts: 263Threads: 1227Joined: Aug 2009it doesn´t appear as an option in the dropdown menu
What you mean “dropdown menu” ?
- February 27, 2018 at 22:52 #14865
gomeztsf
ParticipantPosts: 1Threads: 7Joined: Feb 2018I mean this, i cannot map the networks, since it will screw all the files we have been working on.
- February 27, 2018 at 22:53 #14866
gomeztsf
ParticipantPosts: 1Threads: 7Joined: Feb 2018 - February 27, 2018 at 22:54 #14867
gomeztsf
ParticipantPosts: 1Threads: 7Joined: Feb 2018I already mapped one of our drives to test it. but it wont work for us, how do I add a network location with unc naming
- February 27, 2018 at 23:00 #14868
ModeratorPosts: 263Threads: 1227Joined: Aug 2009 - February 27, 2018 at 23:03 #14869
gomeztsf
ParticipantPosts: 1Threads: 7Joined: Feb 2018i know, but it doesn´t show them, the drives are placed on a main server, that´s why we can´t map them, it only displays the other pcs that are in the network
- February 27, 2018 at 23:11 #14870
ModeratorPosts: 263Threads: 1227Joined: Aug 2009Yes you can’t see in browser unknown and unavailable network paths.
But you can set any path for selected items using the “Set path” menu-item
- February 27, 2018 at 23:28 #14871
gomeztsf
ParticipantPosts: 1Threads: 7Joined: Feb 2018well that´s a shame it wouldn´t work for us in that way
