  • #31364
    Mustafa Beytekin
    Threads: 5
      Recently it started giving this error when I wanted to add xref as I always do. After pressing OK, it seems to have xref inside max, but the screen turns black and nothing is visible. I have to restart Max.
    Plugin version: 3.13.55
    3ds Max version: 2021.3
    Renderer: Octane
  • #31366
      Hello
      As I see from the logs you use the custom script for merging xRefs
      ExecuteString: fileIn “….\\3dsMaxScript\\Merge Xref PROJECTMANAGERDIREKXREFEKLEME.ms”;
      Try to use the standard option
  • #31369
    Mustafa Beytekin
    Threads: 5
    • #31372
        Try to merge several files as xRef manually, using only 3ds Max xRef objects dialog.
        I think there is a problem with 3ds Max and you will receive such problem.
