Viewing 9 posts
  • #30145
    Niklas Keller
      Hi there,
      I do have a question. I’m not sure if it has already been asked. My 3dsMax 2021 freezes a long time after I dragged a 3d model into the scene from Project Manager 3.12.75. (it seems like updates don’t have an effect on the behaviour)
      This happens most of the time when the scene is a getting bigger.
      Has someone the same problem or has someone already figured out how this can be solved?
      Thank you and best regards Niklas
    Plugin version: 3.12.75
    3ds Max version: 3dsMax 2021.2
    Renderer: Vray 5, hotfix 2
  • #30147
      Please generate the bug report and attach one from your scenes.
      Also please try to set the next Place options
      Place On: HomeGrid
      Place Mode: Default
  • #30149
    Niklas Keller
      I think I might have found the solution, it is most likely the “Scene Explorer” which causes this performance issues.
      I’m going to look into this a bit more. Thank you for your fast reply. Hope that I can figure it out on my own.
      [Resolved]
  • #42288
    Raoul Kassab
    Threads: 3
      Hey guys, is this topic resolved? it is really stressful to wait the long times – it could go up to 7 minutes for one import. better then to drag them the old fashioned way.
      Did you find a solution for it? what about the Scene explorer?
      Thanks
    • #42289
        • Use the latest version of Project Manager
        • Turn off the options “Auto-Relink…”
        [Resolved]
  • #42553
    Raoul Kassab
    Threads: 3
      It is still too slow, I am currently waiting for model import for around 12 minutes now.
      Is it the same for everyone? or am I the only one having this issue?
    • #42554
        Just turn off the Auto-Relink options in the Preferences dialog
      • #42555
        Raoul Kassab
        Threads: 3
          I did, it did not work. and what it does is that it does not link the respective maps to the merged model.
          Thank you for making it work
        • #42558
            Also, attach a few from models, that merged slowly.
Viewing 9 posts
