- August 10, 2023 at 12:54 #39542
Mikko Sissala
ParticipantPosts: 1Threads: 1Joined: Oct 2019I just installed PM 2.23.11. Activation was fine, but when I try to start PM, 3ds max freezes, no PM splash screen, nothing. I have to kill max and boot again.
Plugin version: 3.23.11
3ds Max version: 3ds max 2023.3.4 Security Fix
Renderer: Corona v9 - August 10, 2023 at 12:55 #39549
ModeratorPosts: 264Threads: 1268Joined: Aug 2009Try to reinstall the latest update for 3Ds Max
- August 11, 2023 at 19:37 #39559
Mikko Sissala
ParticipantPosts: 1Threads: 1Joined: Oct 2019I have the latest update for max 2023 installed.
I also made a clean installation of max 2024. PM started once, but when I closed max and restarted it and tried to launch PM again, the same thing no splash screen and max freezes.
I also made another test with max 2023 and renamed the ENU folder to make sure that none of the other startup scripts don’t cause an issue with PM. Installed PM. PM launched ok and worked fine for one max session. When I quit max and restarted it the PM does not launch and freezes max again. I repeated this procedure but this time PM does not launch even once. Strange. Any idea what next?
- August 11, 2023 at 22:21 #39560
ModeratorPosts: 264Threads: 1268Joined: Aug 2009Please try version 3.23.15
You can download it from the dashboard
https://3d-kstudio.com/my-account/downloads/ - August 17, 2023 at 19:02 #39600
Harold Rinck
ParticipantPosts: 17Threads: 24Joined: Jun 2012Hi,
Windows 10 installed some updates : KB5027215 or KB5028166,…
It completly kill my connexion with my network synology disks and make 3dsmax freeze when opening Project Manager.
Check and uninstall these updates.
Nevertheless, first opening of Project Manger is slow for me. :-)
Hope it helps.
- August 17, 2023 at 22:41 #39601
ModeratorPosts: 264Threads: 1268Joined: Aug 2009Please check if you turn off all sleep and energy-save functions to your NAS. This might slow down starting the plugin.
- August 18, 2023 at 11:01 #39603
Harold Rinck
ParticipantPosts: 17Threads: 24Joined: Jun 2012Hi, thanks for answer :-) But my files are all localized inside local hard discs. Do Project Manager nevertheless search in the network ?
- August 18, 2023 at 13:45 #39604
ModeratorPosts: 264Threads: 1268Joined: Aug 2009Ok. I was confused by your notes about “network synology disks”
Could you please write a video explaining what you mean about “freeze”?As I understand, Project Manager starts, but with some delay, longer than you expect
- August 18, 2023 at 15:00 #39606
Harold Rinck
ParticipantPosts: 17Threads: 24Joined: Jun 2012Hi, my first post was to try to help Mikko Sissala with my own experience : Win 10 update ( KBxxxx ) make my network disc unreachable and Project Manager non-openable making 3dsmax freezed ( no response, need to hard quit ). As soon I uninstall these updates, all is working fine again.
Then I just said that at first opening, Project Manager is longer than the following.
I don’t know why. :-)
- August 20, 2023 at 20:52 #39627
ModeratorPosts: 264Threads: 1268Joined: Aug 2009Then I just said that at first opening, Project Manager is longer than the following
Please try version 3.23.24
https://3d-kstudio.com/my-account/downloads/This version extremely speed-ups a time of starting the plugin
Time for version 23.21 – 17 sec.
Time for version 23.24 – 5 sec.
Thanks for your feedback
