- May 25, 2016 at 15:03 #9164
ModeratorPosts: 264Threads: 1283Joined: Aug 2009- Adds an ability to use .vrmat files as Material Library.
- Adds an ability to relink external links used in VRayVRmatMtl materials.
- Adds an ability to rendering preview for materials used in .vrmat files.
- Adds support to .bip files – display a preview for .bip files and create biped objects.*
- Fixes a bug when archiving scenes in versions 2.31.12-2.31.22.
- Fixes a bug with relinking Material Library files using the Batch Render&Relink tool.
- Fixes a minor issue with rendering models using the Batch Render&Relink. [Batch Render&Relink]
- Fixes an issue with stopping batch mode with message dialog about read-only files. [Batch Render&Relink]
- Fixes a bug with ‘Batch Render&Relink’ API methods GetDescription and UpdateDescription. [Batch Render&Relink]
- Adds a new property to ‘Batch Render&Relink’ API – BatchMode (return the string Unknown, Render, Relink, Test). [Batch Render&Relink]
Read more about VRayVRmatMtl.
* Biped motion file (BIP).
Saves all information about biped motion: the size and scale of the original biped skeleton, footsteps, keyframe data including limb rotation, the active gravity (GravAccel) value, and prop animation.
IK Blend values for the keys and Object Space settings are also saved.
Read more about Biped motion files.
$60.00Add to Cart
Related to "Project Manager v.2.32.00"
- May 31, 2016 at 19:51 #9897
Harold Rinck
ParticipantPosts: 17Threads: 24Joined: Jun 2012Hi, thanks for this update :-)
As usual I have a request : could it be possible to drag and drop Bips in motion mixer ?
Thanks
- May 31, 2016 at 20:02 #9898
ModeratorPosts: 264Threads: 1283Joined: Aug 2009I’m happy what you find this feature useful.
If it possible i will add a support to motion mixer.
