- August 20, 2022 at 12:19 #36245
- Adds an ability to include/exclude search by asset’s name
- Better search preview thumbnails using a fuzzy search method in the Auto-Assign preview tool
- Ability to open 3Ds Max files in the 3ds Max Material Browser
- Adds an ability to specify a directory to save assets on Save/Export selected objects
- Fixes an issue with saving selected objects in 3ds Max 2014
- Fixes some minor issues with Asset View dialog
- Fixes a bug with opening plugin on scenes that contained Anima objects
- Fixes an issue with overwriting gamma after rendering preview and the option "Overwrite output gamma" is on
The new version of Models Manager gains the ability to open 3ds Max files in the Material Browser.
The preview search with the Auto-Assign Previews tool has also been upgraded. The fuzzy mode now uses a smarter filename matching algorithm.A 3ds Max file can now be opened in the Material/Map Browser from the menu. To open materials from a 3ds Max file, select the scene file from the list in the Models tab. This will open the Material/Map Browser dialog box showing all the materials from the selected scene.
* This feature is available in 3Ds Max 2021 and above.The Auto-Assign Previews tool is designed to search for previews of model and material files.
The new version has an improved preview search, with the fuzzy mode now using a smarter filename matching algorithm.
Select the Fuzzy Search mode and choose a matching level from the Difference drop-down menu (we recommend using Similar or Very Similar). When required, add the words and symbols to be ignored during search (for example, <preview><_>).
Regular expressions (regexes) are also supported.Auto-Assign: ExampleTo match the following previews and 3dsMax files
a2458124_3dh_00007_model02.max -> 00007_model02_02.pnguse these settings:
Filename match: Fuzzy
Ignore:<regex:[0-9,a-z]*_[0-9,a-z]*_>
Difference: Very SimilarClearly, these image names contain some “junk”, which should be excluded. To do this, we use a regex expression to remove the prefixes “d2458163_3dh_”, “a2458124_3dh_” and the like.
The full list of changes for this version is given below.
$22.00Original price was: $22.00.$16.50Current price is: $16.50.Add to Cart
Related to "Models Manager v.2.01.01"
- June 15, 2024 at 10:14 #41940
Jose Ramon Fraga Seivane
ParticipantPosts: 2Threads: 2Joined: Jun 2018Nice
