  • #44200
    Threads: 1195
      The updated PBR Material Generator 1.05 now supports suffixes, allowing you to ignore specific parts of file names when grouping textures.
      PBR Material Generator v.1.05
      🔹 What does this mean?
      You can now specify a regular expression to ignore suffixes, such as _[0-9]*k, ensuring that textures are correctly grouped regardless of their resolution.
      “_[0-9]*K” is the default value. You can add custom suffixes.
      Example:
      If you set the suffix to _[0-9]*k, the following files will be automatically grouped together:
      This helps avoid confusion with different texture resolutions and makes material organization more efficient.
