Viewing 9 posts
  • #44645
    Threads: 5
  • #44648
    Threads: 1284
      Hello
      Check if you used the latest version.
      Try to download and replace this file.
      If the problem still exists, restart the computer.
      There is definitely no such bug in the script, so the problem is most likely with the garbage collector in 3d max.
      Rebooting should help. Also installing or reinstalling the latest service packs and updates.
  • #44649
    Threads: 5
      Hi
      I’m using the latest version, as it’s the only version available for download on the website. I bought it yesterday.
      I’ve done all of this and the same error appears. I don’t know what it could be.
  • #44650
    Threads: 1284
      Try to move the script to local drive
  • #44651
    Threads: 1284
      Check for conflicts with other scripts – close 3ds max and rename the ENU directory.
      Install Project Manager and add the script from the local drive.
  • #44652
    Threads: 1284
      Ok. I found the problem. It will be simpler, if I know version of 3ds max. 3ds Max 2021 has a bug, with optional parameters in the maxscript.
      I’ll post the update soon.
  • #44653
    Threads: 5
      I use 3ds max 2022
  • #44654
    Threads: 1284
      This bug is resolved in version 1.15
      Thanks for feedback
  • #44655
    Threads: 5
      It’s been resolved, thank you very much!
Viewing 9 posts
