  • #37722
    Martin Reznicek
    Threads: 3
      Hello,
      I actually experiment with Fusion I just bought. In my project, I very often use walls with different types/shapes of Bricks. In Fusion, the script is good to use Clone/Fusion distribution but most often problems are on corners of walls. Any change in future add-ons for some better results for “bricks wall” distribution?
      Kind regards
      Martin Reznicek
  • #37724
      Could you please attach the example scene?
      I don’t understand how you want to model walls using Fusion
  • #37725
    Martin Reznicek
    Threads: 3
      Thank you for your quick answer. Just I work on some comerc. projects but immediately when I will more time,
      I will make some sample scenes to send you.
      Also, I have an idea, actually, there is the distribution to the spline, would be great possible distribute inside the closed spline as a “scatter” for fulfilling by paving/tile for examp.  with an offset between tiles. But maybe it is too difficult for implementation.
      Kind regards
      Martin
