- April 12, 2022 at 17:51 #35229
Bert McCumber
ParticipantPosts: 1Threads: 0Joined: Apr 2022 - April 12, 2022 at 17:53 #35231
ModeratorPosts: 263Threads: 1238Joined: Aug 2009Hello
There is no ability to set a custom path to installation - August 10, 2022 at 21:20 #36160
Joshua Jay
ParticipantPosts: 0Threads: 1Joined: Jul 2022 - August 14, 2022 at 23:37 #36186
ModeratorPosts: 263Threads: 1238Joined: Aug 2009- Create the object in the viewport and switch to the Modify tab
- Open the License rollout at the bottom and press the button License
https://3d-kstudio.com/faq/installation-and-reception-of-license-key/
- October 26, 2022 at 00:00 #37144
Filis Guillaume
ParticipantPosts: 1Threads: 2Joined: May 2020Hello,
Is the option to set a custom path to installation will be implemented soon ? The halloween sale is tempting but if i can’t use the plugin, it’s useless ( Max is on another drive, D).
Can’t even try the Demo…
If it’s still not the case, it should be cleary mentionned on the store page !
- October 26, 2022 at 08:10 #37148
ModeratorPosts: 263Threads: 1238Joined: Aug 2009…Max is on another drive, D
it does not affect to functionality of the plugin in any way. I’m also having 3ds Max installation on D
- October 26, 2022 at 09:22 #37149
Filis Guillaume
ParticipantPosts: 1Threads: 2Joined: May 2020My bad,
I tried the demo but couldn’t make it work and found this thread, but after some tweeking i found that i didn’t place the”en-US” of the “RENDER_VERSION” in the right place.
Please add a .txt or put installation guidelines inside the manual, feel like i was cracking the plugin ….
(For those wondering: Add the content for your max version of the “RENDER_VERSION” inside the plugin folder of your max installation: the “en-US” folder don’t go at the root).
Thank you, and sorry if my english is not clear ^^.
- October 29, 2022 at 05:41 #37167
ModeratorPosts: 263Threads: 1238Joined: Aug 2009Use the RENDER_VERSION only on render-nodes.
Versions for rendering don’t have the interface and required only for rendering.
So for using – remove any manually placed directories and use the EXE files to install the plugin.
PS. The latest version (uploaded yesterday) fixes a problem with installing for customers who have several user-profile directories for 3ds max.
Looks like this is your case. Just download and install the latest version. Sorry for the inconvenience.
