Creation Curlipse
Interface
Creation Method rollout
Keyboard Entry rollout
Parameters rollout
Length
Width
Height
Outline. Thickness. Close
No Outline
With Outline
Closed Curlipse with Outline
Expansion
Expansion: 0
Expansion: 1
Expansion: -1
Points
Turns
CW/CCW
Bezier/Corner
Project Manager
Oleksandr Kramer –
Thank you!
