- April 3, 2024 at 22:25 #41388
Keith Lee
ParticipantPosts: 5Threads: 9Joined: Nov 2022::Hi,
That new option to process xref scenes in batch relink makes unwanted changes to those scene settings. For example, it turns on the “Match Layers by Name and Parent” option for each xref scene record, which screws up layers coming in from those scenes, and it changes all relative paths to full paths. It should not doing any of this.
Plugin version: 3.35.20
3ds Max version: 2024.2
Renderer: vray - April 3, 2024 at 22:31 #41390
ModeratorPosts: 264Threads: 1280Joined: Aug 2009The plugin doesn’t change the “Match Layers by Name and Parent” option.
Check your scripts or other options for this.it changes all relative paths to full paths.
This behavior didn’t change – the plugin always changed paths to full.
But this is a good idea – in the future, I’ll add the ability to use the relative paths.PS. Latest version is 3.35.23
- April 3, 2024 at 22:42 #41391
Keith Lee
ParticipantPosts: 5Threads: 9Joined: Nov 2022Hi,
The batch render and relink was the only tools I used on these files; the option “Match Layers by Name and Parent” is always off on my xref scenes. That option is on by default, so if the tool changed the path from relative to full path then that likely triggered it to be turned on regardless because that option is always on for added xref records.
- June 18, 2024 at 23:39 #41953
Keith Lee
So, I did put in a feature request to Autodesk to get the default behavior of “Match Layers by Name and Parent” to be controlled by script. Apparently, there is no way to control it by script right now, so if the path is changed for an XREF it will get turned on again if originally turned off. Unwanted in my case.
