Viewing 6 posts
  • #27762
    j.a.b
    Threads: 3
      Hello!
      I’m very new to Project manager and am loving it so far. Great job!
      I have a very specific layer structure I use for projects, and it would be very handy to be able to select a layer, and then drag-and-drop merge objects and have them automatically be moved to that layer. This could possibly be an option
  • #27764
    Threads: 1217
      You can do this using Project Manager API
      Save the next script to file “MovetoCurrentLayer.ms” and place it to the startup scripts directory.
      Restart 3ds max.
      fn MovetoCurrentLayer &PostMergeStruct =
        local layer = layermanager.Current
        for obj in PostMergeStruct.Nodes where isValidNode obj and not isDeleted obj do
          layer.addNode obj
      if (superClassOf PmCallbacks == structDef) do (
        PmCallbacks.removeScripts CallbackID:#MovetoCurrentLayer
        PmCallbacks.addScript #postFileMerge MovetoCurrentLayer CallbackID:#MovetoCurrentLayer
      For details see the example about callback #postFileMerge on the page
      https://3d-kstudio.com/faq-cat/maxscript-api/
      Have a good day!
  • #27765
    j.a.b
    Threads: 3
      Fantastic! Thank you :)
      Is there a spot where your examples such as this are saved? I’m sure there are a lot of handy scripts like this you’ve made…
  • #30854
    KARIM HASSAYOUNE
    Threads: 5
      Hey,
      Did this script work for you ?
      I saved it to the startup scripts folder as instructed but it does seem to work.
      I tried running this command :
      PmCallbacks.Show()
      and it returns this :
      #postFileMerge:
      CallbackId:#MovetoCurrentLayer, MovetoCurrentLayer()
      So the callback seems to be added properly right ?
  • #30856
    Threads: 1217
      Hi
      Yes – it should be work.
      Note that now Project Manager has a related option in the Preferences.
      Move 3d models to the active layer
      [Resolved]
  • #30857
    KARIM HASSAYOUNE
    Threads: 5
      Ah yes, ok perfect.
      Thank you.
Viewing 6 posts
