- April 11, 2022 at 13:32 #35213
TomTNT
ParticipantPosts: 2Threads: 0Joined: Mar 2022::Hi, would be/Is it/ possible to generate proxy for selected files – library without need to add them to the scene? I would like to pre-generate proxies for my libs. Also, how to filter files that already have/don’t have proxies?
And third thing – Now, you generate one proxy for scene with more than one meshes. Would be fine, to have option to generate proxy for each mesh in the scene. (typical a library of grass with more clumps etc) There is need to solve the problem of more proxies and one thumbnail…
I sometimes have a problem with vray proxy generator. Usually it stops working after more than 5-10 converting. So I need to start new max session and continue of converting.
Thanks for a help.
- April 11, 2022 at 13:45 #35215
ModeratorPosts: 264Threads: 1257Joined: Aug 2009Is it/ possible to generate proxy for selected files – library without need to add them to the scene?
This ability is already presented in the Project Manager. Just use the desired format from the menu item “Export to:”
PM doesn’t have such an option, because there isn’t sense in this.
Just turn on the option “Merge as Proxy” and “Use existing Proxy”[Resolved]
