- June 24, 2022 at 10:04 #35788
Thomas C
ParticipantPosts: 14Threads: 45Joined: Mar 2022Hi Alex,
I have the following issue:
_ I browse a folder containing 3d models preview (.jpg format)
_ I activate the “View image (Space)” feature to see a bigger image
_ one of the enlarged view doesn’t match the correct preview
I recorded a video where you clearly see the issue: https://web.tresorit.com/l/fM3n2#U9sng_KF5mxDEvJ8XeaYMw
When I select “VOL_195___DRINKS_COC_05.jpg” file, the bigger image displayed is not “VOL_195___DRINKS_COC_05.jpg”, but “VOL_195___DRINKS_COC_03.jpg” instead (although the name of the file correctly shows “VOL_195___DRINKS_COC_05.jpg”).
I tried refreshing the folder but the issue remains.
Thank you for your support Alex, much appreciated.
Plugin version: 3.18.24
3ds Max version: 2022.3.3
Renderer: Corona 8 Hotfix 1 - June 24, 2022 at 10:13 #35791
ModeratorPosts: 264Threads: 1282Joined: Aug 2009 - June 24, 2022 at 11:12 #35792
Thomas C
ParticipantPosts: 14Threads: 45Joined: Mar 2022Fantastic!
Thanks a lot Alex :)
