- June 20, 2012 at 03:59 #9643
Michael Gregg
ParticipantPosts: 1Threads: 1Joined: Jun 2012- run Max2012 as administrator.
- disable UAC.
I get this MAXScript error whenever I try to update PM:
–Runtime error: dotNet runtime exception: The remote server returned an error: (417) Expecation Failed.
I’ve searched around but haven’t found a solution. Things I’ve tried that did not work:
Is there a way to install the update manually? Any help you can provide will be greatly appreciated.
- June 20, 2012 at 08:45 #9644
ModeratorPosts: 264Threads: 1285Joined: Aug 2009 - June 20, 2012 at 22:17 #9645
Michael Gregg
ParticipantPosts: 1Threads: 1Joined: Jun 2012Thanks. Now I’m up to date.
I’ll post if the next update installs correctly.
