  • #9817
    Bordo Rights
         Hello;
      Something must be awfully wrong as both “model manager” and “project manager”FAILS to show the files inside the added folder.
      example structure:
      Folder__teapot.max
      Folder__teapot.jpg.
      Result= Nothing.
      A very old, 1.65xx etc version shows just fine but the proper versions do not….
      There is another question:
      I tag the jpg files with tags like “interior, furniture, sitting, chair, side,hq,classical,european” i am really curious of how searching is handled in Project manager… Does it search tags?
      Since you have left out the most important feature, i have to buy to try it?
      do you offer refunds? How long is the refund period? are there any other ways?
      QUESTION 3:Things get complicated easily if the models dont have properly named textures… Can Project manager support this:
      Folderteapot.max
      Can it somehow figure out to prefer and look inside the Same named subfolder (before checking with the general external paths?
      Also, when saving a model to the library? Can it also create subfolders with model’s name and put textures in there?
      You know what, maybe you should reall produce a “real” demo just so nobody loses time.
      ps: there should definitely be a feature that lets you save the current “render frame window” as the thumbnail of the selected model.
      Thank you
  • #9818
      1) Sorry – i cannot reproduce this – all files is showing.
      What version of plugins you used? Maybe you need update to latest version.
      2) The searching by description now work only with 3d files.
      But i planning add the the ability to searching the images by tag and description.
      3) In this case a maps will be relink on the fly.
      4) When you save the model to library the maps save to subfolders with model’s name. It so as always.
  • #9819
      The last version of the “Project Manager” supports writing and search for tags and comments from the image files.
      Project Manager v.2.23.07
