  • #35365
    Suissa Nicolas
    Threads: 0
      HEllo
      I changed computer and when I import my library it does not find any textures. I don’t have the same access path as on the other computer, do I have to redo all my textures?? or can we modify thank you so much
    Plugin version: 3
    3ds Max version: 3dsmax 2023
    Renderer: Corona render
  • #35370
      The simplest and fastest way – there is to move textures to the same location as on the previous computer.
      In another way, you can batch change the links using Batch Render&Relink tool.
      Use the Find & Replace function in combination with Fast Mode
      Be attentive and tests the mask to find/replace before applying this operation to the entire library
