- November 20, 2024 at 12:10 #43145
Vjekoslav Kiraly
ParticipantPosts: 1Threads: 1Joined: Dec 2019Hi, when I have a new scene, and I drag a few objects in, and want to link the textures, Project manager is always asking to save the 3ds max file before doing that. When I was on File Path finder pro previously, I didn’t have that message. Is it possible to turn off that pop-up window?
Plugin version: 3.36.41
3ds Max version: 2024
Renderer: FStorm/Corona - November 20, 2024 at 12:11 #43147
You should save a file before relinking - November 20, 2024 at 12:15 #43148
Vjekoslav Kiraly
ParticipantPosts: 1Threads: 1Joined: Dec 2019Thanks, however while using Pathfinder Pro, I never had to do that, so there’s no way on turning that off?
Because I have a “scrap” max instance, where I import all models, clean them, then transfer to an actual scene. With this I always need to save these scrap max files- November 20, 2024 at 18:07 #43156
ModeratorPosts: 264Threads: 1283Joined: Aug 2009I will check for this. In some cases, it might be possible without saving current scene
