- January 5, 2020 at 14:52 #24975
Man Mars
ParticipantPosts: 9Threads: 12Joined: Dec 2019In some cases, I have to modify the material after merging object (as proxy) into scene.
For example, converting from Vray mat. to Corona mat. and make some tweaks.
Then, I want to save the model overwriting the old one.
PM let me do this but it will create a .max file, can I save it with proxy format (.cgeo) and this will overwrite the existing one? - January 5, 2020 at 14:58 #25022
ModeratorPosts: 263Threads: 1239Joined: Aug 2009If you work with the mat when you must rewrite the related mat file in a directory with Proxy.
It should have a name like your proxy filename + extension “.mat”
- January 8, 2020 at 16:09 #25167
Man Mars
ParticipantPosts: 9Threads: 12Joined: Dec 2019I miss this method. Thank you!
