  • #24975
    Man Mars
    Threads: 12
      In some cases, I have to modify the material after merging object (as proxy) into scene.
      For example, converting from Vray mat. to Corona mat. and make some tweaks.
      Then, I want to save the model overwriting the old one.
      PM let me do this but it will create a .max file, can I save it with proxy format (.cgeo) and this will overwrite the existing one?
  • #25022
    Threads: 1284
      If you work with the mat when you must rewrite the related mat file in a directory with Proxy.
      It should have a name like your proxy filename + extension “.mat”
  • #25167
    Man Mars
    Threads: 12
      I miss this method. Thank you!
