- September 21, 2021 at 20:05 #33449
Michael Salak
ParticipantPosts: 1Threads: 2Joined: Sep 2021Getting this runtime error when starting up project manager in 3ds max 2022. Tried to update/reinstalled plugin even 3ds max and its still there.
— Error occurred in anonymous codeblock; filename: C:\Users\misas\AppData\Local\Autodesk\3dsMax\2022 – 64bit\ENU\scripts\Kstudio\ProjectManager_3\Main.mse; position: 1056; line: 17
— Runtime error: .NET runtime exception: Could not find a part of the path ‘E:\Vray\bin\plugins’.
— MAXScript callstack:
— thread data: threadID:11500
— [stack level: 0]
— In anonymous codeblock; filename: C:\Users\misas\AppData\Local\Autodesk\3dsMax\2022 – 64bit\ENU\scripts\Kstudio\ProjectManager_3\Main.mse; position: 24077; line: 238
— Defined in encrypted script
— [stack level: 1]
— called from execute(); filename: C:\Users\misas\AppData\Local\Autodesk\3dsMax\2022 – 64bit\ENU\scripts\Kstudio\ProjectManager_3\Main.mse; position: 1057; line: 17
— member of: codeblock macroScript: Kstudio_Project_Manager_3
— [stack level: 2]
— called from codeblock macroScript: Kstudio_Project_Manager_3
— Locals:
— Externals:
— [stack level: 3]
— called from top-levelPlugin version: 3.15.74
3ds Max version: 3ds Max 2022
Renderer: corona - September 21, 2021 at 20:08 #33459
ModeratorPosts: 264Threads: 1282Joined: Aug 2009Please generate the support request.
- September 21, 2021 at 22:02 #33461
ModeratorPosts: 264Threads: 1282Joined: Aug 2009This issue is fixed in version 3.15.76
Thanks for your feedback. - September 21, 2021 at 22:32 #33463
Michael Salak
ParticipantPosts: 1Threads: 2Joined: Sep 2021Just updated but the issue is still there. Its exactly the same.
- September 22, 2021 at 03:04 #33467
ModeratorPosts: 264Threads: 1282Joined: Aug 2009Sorry, I uploaded a non-updated version earlier.
Please download again. Now it should work.
- September 22, 2021 at 14:55 #33470
Michael Salak
ParticipantPosts: 1Threads: 2Joined: Sep 2021Awesome ! Thank you for quick fix.
