Viewing 6 posts
  • #33449
    Michael Salak
    Threads: 2
      Getting this runtime error when starting up project manager in 3ds max 2022. Tried to update/reinstalled plugin even 3ds max and its still there.
      — Error occurred in anonymous codeblock; filename: C:\Users\misas\AppData\Local\Autodesk\3dsMax\2022 – 64bit\ENU\scripts\Kstudio\ProjectManager_3\Main.mse; position: 1056; line: 17
      — Runtime error: .NET runtime exception: Could not find a part of the path ‘E:\Vray\bin\plugins’.
      — MAXScript callstack:
      — thread data: threadID:11500
      — [stack level: 0]
      — In anonymous codeblock; filename: C:\Users\misas\AppData\Local\Autodesk\3dsMax\2022 – 64bit\ENU\scripts\Kstudio\ProjectManager_3\Main.mse; position: 24077; line: 238
      — Defined in encrypted script
      — [stack level: 1]
      — called from execute(); filename: C:\Users\misas\AppData\Local\Autodesk\3dsMax\2022 – 64bit\ENU\scripts\Kstudio\ProjectManager_3\Main.mse; position: 1057; line: 17
      — member of: codeblock macroScript: Kstudio_Project_Manager_3
      — [stack level: 2]
      — called from codeblock macroScript: Kstudio_Project_Manager_3
      — Locals:
      — Externals:
      — [stack level: 3]
      — called from top-level
    Plugin version: 3.15.74
    3ds Max version: 3ds Max 2022
    Renderer: corona
  • #33459
  • #33461
      This issue is fixed in version 3.15.76
  • #33463
    Michael Salak
    Threads: 2
      Just updated but the issue is still there. Its exactly the same.
    • #33467
        Sorry, I uploaded a non-updated version earlier.
        Please download again. Now it should work.
  • #33470
    Michael Salak
    Threads: 2
      Awesome ! Thank you for quick fix.
Viewing 6 posts
