  • #25110
    as3465346
    Threads: 0
      Suddenly started getting this error trying to run project manager, only just started happening today. Udated and uninstalled/reinstalled and error persists:
      — Runtime error: .NET runtime exception: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the NET Framework. This release of the NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/ fwlinkfilinkId =155569 for more information.
    Plugin version: 3
    3ds Max version: 2018
    Renderer: vray
  • #25117
      Try the next
      Download the archive manually.
      After, unblock the archive by right-clicking on it in Explorer and selecting “Properties” and “Unblock”.
      unblock the archive
      Remove the ProjectManager directory.
      Extract the archive and install.
      https://labs.blogs.com/its_alive_in_the_lab/2011/05/unblock-net.html
      If this didn’t help check the properties of directory ENU and subfolders.
  • #33405
    Threads: 14
      Hi, I´m having same trouble, but with a message a little different:
      — Runtime error: .NET runtime exception: Illegal characters in path.
      What can I do?
      Thanks.
    • #33406
        Please generate the support request
