  • #36733
    Gethin Hooper
    Threads: 6
      I’m trying to batch run a script on hundreds of files -some of which have corruptions triggering 3dsmax security tools. If I open the files manually, security tools asks if I want to clean the file and re-save. Done. No problems. If I run batch render-relink to run the script only, it crashes out on these files. My script is simple script to remove animation layers which are slowing my system down. Is there a way to add the .net event or  close the security tools window as part of the batch process?
    3ds Max version: 2021
    Renderer: corona
  • #36753
      Just fix these files before batch processing
