  • #33905
    Threads: 2
      I just bought and installed Project Manager v3. When I start 3ds max 2021 it crashes to the desktop immediately upon start up. I’m trying to uninstall it to see if PM3 is causing the problem but I can’t do it through the Max UI menu. How do I manually uninstall it?
    Plugin version: 3
    3ds Max version: 2021
  • #33907
    Threads: 1248
      Strange, because, Project Manager almost doesn’t load anything when starting 3ds Max.
      To removing startup scripts, just delete the file “%localappdata%\Kstudio\data\Callbacks\KstudioCallbacks.mse”
      and KstudioSaveStudioFile.mse and ProjectManager_3.ms from the user startup scripts.
      Find me tomorrow on skype as alexkstudio, if the problem still persists
  • #33909
    Threads: 2
      Thank you for the help. I uninstalled it but the crashes do not seem to be associated with the Project Manager.
  • #34020
    Threads: 2
      After several days, and re-installs, I finally managed to get Max running correctly. PM is installed and there have been no issues so far. Actually, the first use literally doubled the value of what I paid for it.
      Question: Is it possible to add menu categories to the left vertical options? I am talking about the Models/Materials/Textures/IES menu.
