  • #24951
    Man Mars
    Threads: 12
    As I remember, this issue has happened since I update PM to version 3.07.91. Every time I use “AddToForest” utility, the created proxies always miss texture.
    But if I merge model as proxy in normal way, there is no problem.
    Then I apply these proxies to forest plugin, there is no problem, too.
    Is this a bug?
    Plugin version: 3.07.91
    3ds Max version: 2018
    Renderer: Corona
  • #25024
    If you open the script you can see the next line at start:
    This script demonstrates the ability to add a custom capabilities to plugin using API
    Scripts in the directory “API examples” for demonstrating how to write custom extensions for Project Manager. So you can write a custom extension using the ‘AddToForest.ms’ as an example.
  • #25165
    Man Mars
    Threads: 12
    Unfortunately, I don’t know scripting. I should do it in normal way.
    Thank you.
