  • #29617
    Threads: 3
      Hi guys,
      Does anyone know why if you try to add new folders & content to your network, project manager’s folder structure doesn’t update to reflect this? The only solution is to exit Max and re-open it again, obviously a pain. Also I have tried manual drag and drop as per the tutorial and this gets ignored if one has a directory already there and you are adding only a few sub folders, very weird !!
      Many thanks,
      Jason
    Plugin version: 3.12.31
    3ds Max version: 2020.3.2
    Renderer: Vray
  • #29619
    Threads: 1195
      project manager’s folder structure doesn’t update…
      Activate the treeview and press F5 or use the menu-item Refresh
      I have tried manual drag and drop as per the tutorial and this gets ignored if one has a directory already there..
      What reason for duplicating directories?
  • #29620
    Threads: 3
      Thanks Alex, much appreciated, I had been pressing the refresh folder icon, hadn’t realised there was another refresh, much appreciated :)
      Jason
  • #29621
    Threads: 3
      Ah, problem still there! The refresh worked once, since then no luck. Very peculiar.
      Thanks,
      Jason
