- September 23, 2020 at 14:15 #29617
luckett_jason@hotmail.com
ParticipantPosts: 2Threads: 3Joined: Feb 2015Hi guys,
Does anyone know why if you try to add new folders & content to your network, project manager’s folder structure doesn’t update to reflect this? The only solution is to exit Max and re-open it again, obviously a pain. Also I have tried manual drag and drop as per the tutorial and this gets ignored if one has a directory already there and you are adding only a few sub folders, very weird !!
Many thanks,
Jason
Plugin version: 3.12.31
3ds Max version: 2020.3.2
Renderer: Vray - September 23, 2020 at 14:22 #29619
ModeratorPosts: 264Threads: 1283Joined: Aug 2009project manager’s folder structure doesn’t update…
Activate the treeview and press F5 or use the menu-item Refresh
I have tried manual drag and drop as per the tutorial and this gets ignored if one has a directory already there..
What reason for duplicating directories?
- September 23, 2020 at 14:36 #29620
ParticipantPosts: 2Threads: 3Joined: Feb 2015Thanks Alex, much appreciated, I had been pressing the refresh folder icon, hadn’t realised there was another refresh, much appreciated :)
Jason
- September 23, 2020 at 14:59 #29621
ParticipantPosts: 2Threads: 3Joined: Feb 2015Ah, problem still there! The refresh worked once, since then no luck. Very peculiar.
Thanks,
Jason
