Viewing 10 posts
  • #18196
    Michal Ziobro
    Threads: 40
      Alex,
      Can I control preview render by Corona noise limit? – for me doesnt work – Corona 3.0 :(
      And second question – do You planning corona vfb support for rendering thumbs?
      Best
      Michal
  • #18214
    Threads: 1195
      Thanks for your question – I”l will check for this issue.
      This also. If last corona version did receive some capabilities I’ll add this feature.
  • #18266
    Threads: 1195
      Project Manager version 2.95.40 now supports to Corona vfb.
  • #18267
    Michal Ziobro
    Threads: 40
      Thank you very much
  • #19694
    Demetrio Ruivo
    Threads: 6
      Hi Alexander, my Corona Renderer is not working with the corona VFB – Nor is the output from the default Max VFB saving things correctly to our library – is there an update coming to Corona 4.0? It will render, the thumbnail fine, but it is not saving and replacing the viewport generated thumbnail with the rendered one.
      Thanks
    • #19699
      Threads: 1195
        This is a bug in Corona 4
        Corona 4 generates the exception on rendering start with simple maxscript command
        bm = render vfb:false
        You can report about this bug to developers.
    • #19970
      Threads: 1195
  • #19989
    Hypershade
    Threads: 8
      Corona hotfix 1 solved the problem of saving images. Now I have an another problem and a question.
      It seems that Project Manager doesn’t doesn’t use the noise level limit from the .rps files. It doesn’t matter what limit I set, the rendering is always ends at the same/time, leaving me with very noisy thumbnails like this. This is with noise level limit 2%.Noise level 2%
      It worked before. If I use e.g time limit, it works, but obviously I can’t use the same time or passes for every material.
      Do you have any idea what causes this?
      And my question: how can I switch to the Corona VFB during thumbnail rendering, even if I render them one by one.
      Thank in advance.
  • #20007
    Threads: 1195
      This issue is fixed in version 2.96.23
      You can download latest version from dashboard.
      Auto-updater will be triggered in few days if there’s no critical issue found.
  • #20111
    Hypershade
    Threads: 8
      Hi Alex,
      thanks it’s works perfectly well, Corona VFB also.
Viewing 10 posts
