  • #39678
    Fabian Fassbind
    Threads: 0
      Hi, I have a Problem with connecting to my MySQL Database. If I switch to MySQL in the Preferences Menue I can successfully test the connection, but if I close the Menue the setting gets swapped back to SQLite and I’m getting the following errors:
      SQLite error (261): database is locked in “SELECT name FROM sqlite_master WHERE type=’table’ AND name LIKE ‘options’;”
      SQLite notice (283): recovered 6 frames from WAL file C:\Users\Büro_Fabian\AppData\Local\Autodesk\3dsMax\2024 – 64bit\DEU\scripts\Kstudio\ProjectManager_3\Settings\AssetSQLiteCache.db-wal
      SQLite error (15): locking protocol in “SELECT name FROM sqlite_master WHERE type=’table’ AND name LIKE ‘options’;”
      MySQL was already running fine before the last major update.
    Plugin version: 3.23.27
    3ds Max version: 3ds Max 2024 SP1
    Renderer: Corona
  • #39680
      Hello
  • #39684
      Please check MySQL settings.
      Currently, it returns the next error message:
      MySqlException (0x80004005): You do not have the SUPER privilege and binary logging is enabled (you *might* want to use the less safe log_bin_trust_function_creators variable)
