Viewing 10 posts
  • #19248
    François Filliat
    Threads: 4
      I have a very strange issue with the batch rendering. I have a big database to render so i put the paths i need to render on the batch relink&render panel then setup everything as i need. When i press the run button everything looks good. But when i get a closer look some files are skipped.
      I opened the log and the skipped files are marked as containing no object.
      Obviously they contain editable mesh objects. I tried to put all the objects in layer0 but it does not fix the problem.
      Do you have any idea ?
      Many thanks.
    Plugin version: 2.95.40
    3ds Max version: Max 2016 (18.0)
    Renderer: VRay
  • #19250
      Please generate the bug report.
  • #19251
    François Filliat
    Threads: 4
      Done ! ;)
    • #19253
        1) It looks like a problem with ALC 3ds max virus
        Here you can read more about this problem and solution – https://3d-kstudio.com/support/faq/#16028
        ALC Security Tool 1.0 – ALC corruption found in file: Sample_Studio_2.max
        ALC Security Tool 1.0 – Automatic cleanup of ALC in scene performed since in quiet mode.
        ALC Security Tool 1.0 – Automatic cleanup of ALC from the current scene performed, file: Sample_Studio_2.max
        2) The script “ToLayer0.ms” that you use as post-open doesn’t work properly. Turn off it or fix a problem in this script.
      • #19528
        François Filliat
        Threads: 4
          Hi Alexander,
          Thank you for your feedback. I already installed 3DSMax security tool and it don’t detect any corruption in my custom studio.
          Morever, it works for almost all files. If the corruption was really the problem I think it would have crash every rendering.
          The script “ToLayer0.ms” was used to fix the problem i already disabled it.
          I’m out of ideas. Strange fact is when a file is skipped it looks like it’s added to the studio until a “valid” file is rendered. After multiple invalid files loads, the loading times increase because the studio scene can contain a lot of meshes (see picture bellow).
          Every green bounding box contain meshes
          If you have any other idea it would be wonderful ! ;)
          François
        • #19529
            Try reset settings to default and render using default settings.
            For resetting settings open the “Preferences” dialog and press the button “Reset settings”.
          • #19540
            François Filliat
            Threads: 4
              Hi Alexander,
              I reseted the settings but for now 3DSMax crashes when it loads the previously skipped files…
              Even if i revert back to my custom studio, the error are the same. The files that are skipped don’t seems to have a different structure. No ALC corruption detected as well in these files.
              T_T
              François
          • #19543
              Please send some from those files to support@3d-kstudio.com
          • #19680
            François Filliat
            Threads: 4
              Hi Alexander,
              It looks like I managed to fix the problem. FYI when a max file contains a Container it’s marked as containing no object by the Batch Renderer.
              I delete the containers and it seems to work now.
              Regards,
              François
          • #19685
              Thanks for your feedback – I’ll add support to container in next version.
Viewing 10 posts
