- November 11, 2020 at 13:08 #30145
Niklas Keller
ParticipantPosts: 1Threads: 1Joined: Oct 2016Hi there,
I do have a question. I’m not sure if it has already been asked. My 3dsMax 2021 freezes a long time after I dragged a 3d model into the scene from Project Manager 3.12.75. (it seems like updates don’t have an effect on the behaviour)
This happens most of the time when the scene is a getting bigger.
Has someone the same problem or has someone already figured out how this can be solved?
Thank you and best regards Niklas
Plugin version: 3.12.75
3ds Max version: 3dsMax 2021.2
Renderer: Vray 5, hotfix 2 - November 11, 2020 at 13:13 #30147
ModeratorPosts: 263Threads: 1248Joined: Aug 2009 - November 11, 2020 at 19:10 #30149
Niklas Keller
ParticipantPosts: 1Threads: 1Joined: Oct 2016I think I might have found the solution, it is most likely the “Scene Explorer” which causes this performance issues.
I’m going to look into this a bit more. Thank you for your fast reply. Hope that I can figure it out on my own.
[Resolved]
- August 14, 2024 at 11:22 #42288
Raoul Kassab
ParticipantPosts: 0Threads: 3Joined: Jan 2023Hey guys, is this topic resolved? it is really stressful to wait the long times – it could go up to 7 minutes for one import. better then to drag them the old fashioned way.
Did you find a solution for it? what about the Scene explorer?
Thanks- August 14, 2024 at 15:34 #42289
ModeratorPosts: 263Threads: 1248Joined: Aug 2009- Use the latest version of Project Manager
- Turn off the options “Auto-Relink…”
[Resolved]
- September 6, 2024 at 11:21 #42553
Raoul Kassab
ParticipantPosts: 0Threads: 3Joined: Jan 2023It is still too slow, I am currently waiting for model import for around 12 minutes now.
Is it the same for everyone? or am I the only one having this issue?- September 6, 2024 at 12:27 #42554
ModeratorPosts: 263Threads: 1248Joined: Aug 2009Just turn off the Auto-Relink options in the Preferences dialog
- September 6, 2024 at 12:37 #42555
Raoul Kassab
ParticipantPosts: 0Threads: 3Joined: Jan 2023I did, it did not work. and what it does is that it does not link the respective maps to the merged model.
Thank you for making it work- September 6, 2024 at 16:41 #42558
ModeratorPosts: 263Threads: 1248Joined: Aug 2009Please generate the support request.
Also, attach a few from models, that merged slowly.
