  • #40427
    dream_co
    Threads: 2
      The latest 3dsmax 2024 update 2 breaks the “Object Paint&Place” window and the on-screen text help. None are showing when you drag a model from PM into the scene. The rotate and such shortcuts are not working too. Just a single click to place the object once and then the operation stops without the ability to place more copies. Tested with three previous versions of PM.
      object paint bug
    Plugin version: 3.23.70
    3ds Max version: 2024 Update 2
  • #40429
      Looks like you exclude all object types from merging
      I see in the logs a next line: Skip objects: #(Editable_Poly) [Count: 1]
      Resetting the exclude option to default should help you
  • #40431
    dream_co
    Threads: 2
      I did use the default preset but unfortunately the problem remains :(screenshot_1
