Custom Exclude Expression – Merge 3D Models by your rules
Tagged: Project Manager, Project Manager - Update History, Project Manager version 3, Update History
- July 8, 2025 at 05:26 #45151
In team-work mode (MySQL/MariaDB) caching is much faster;
In local mode (SQLite), it’s slower, especially with large libraries.
- Modern furniture (tables, chairs, armchairs),
- Decorative plants and small trees,
- Landscape trees for exteriors,
- Accessories and decor elements for interiors.
- Interactive search across the entire database — enter a query and see the desired results immediately!
- Interactive complex filters with include/exclude conditions for Filename, Descriptions, and Categories
- Separate Filter and Search text boxes for clearer workflows
- Locate assets by their complete folder path for more precise filtering
- Added a filter textbox in the Categories dialog
- Option to disable scanning for missing external links across the entire database—only user-specified folders will be scanned (Preferences → Database)
- Added "Isolate Selection" filter
- Added ability to assign and filter by Color Labels
- Significantly speed up asset filtering
- Significantly improved asset display speed for large file sets
- Enhanced navigation responsiveness across all views
- Smoother preview thumbnail caching for quicker loading
- Improved UI responsiveness for a more fluid browsing experience
- Eliminated interface freezes when handling uncached thumbnails
- Redesigned bottom-panel layout, with an option to hide it
- Ability to disable some default shortcuts [ "Customize" => "Customize Shortcuts" => "System Shortcuts"]
- New shortcuts - Ctrl+F to focus Search textbox, and Ctrl+Shift+F to focus Filter textbox
- Support for hiding folders by relative path (per parent node), enabling more precise control over which folders are hidden
- Unified gallery and material tree into a single pane with tabbed views (Materials tab)
- Added "Batch Rename", "Convert Images", and "Open With..." buttons to the main toolbar
- Expanded texture data display to include color mode and bit depth
- New options to replace diacritic characters and transliterate Cyrillic text to Latin
- Ability to specify the increment step for sequential numbering of files
- Resolved an issue affecting batch conversion of files between formats
- Fixed minor issues with the Batch Render & Relink tool
- Ability to specify custom expression to exclude objects from merging
- Resolved a bug in 3ds Max 2023 and earlier related to placing materials into the Slate Material Editor (SME)
- Improved detection of appropriate material slots when creating PBR materials from maps with specific naming patterns
- Shipped with 13 new 3D models from Evermotion
- Resolved UI rendering problems on high-DPI displays at specific scale settings
- Fixed gallery update for selected items upon addition or removal
- Resolved an issue when searching within categories only
- Option to clear cached data from the database [Preferences → Database → Clear Cache]
- Fixed several bugs in 3ds Max 2026
- Other minor fixes, optimizations, and interface improvements
Experience a New Level of Speed and Control for Your 3D Asset Library
Don’t waste time searching—whether your asset library is perfectly organized or absolute chaos, the new Project Manager with instant search lets you find any file in seconds.
Speed is the core idea of this release: now, even folders with thousands of files open instantly, search happens with no delays, and complex filters are applied in a flash.
Search / Filtering / Navigation: Speed You Can Feel Instantly
The moment you start typing your query, interactive search instantly brings up relevant results—no need to hit Enter, no lags, even if your database contains hundreds of thousands of assets.
Various search and filtering options are available: simple filename filters, full path, description, and include/exclude by keywords. You can search across the entire library or just in selected folders (Do you know you can select multiple folders at once using Ctrl/Shift?)The new filtering engine works in tandem with search. As you add or remove include/exclude conditions by name, description, or category, the list updates instantly.
Navigation through folders is also significantly improved—folders with thousands of files now open very fast! Forget about interface freezes—even uncached thumbnails no longer slow you down.
TIPS:
To get the full benefit of interactive search, enable the Assets Cache option (Preferences → Database → Assets Cache).
After enabling it, your assets will be gradually cached in the background, without interfering with your work.
Caching speed depends on your connection type:Depending on the size of your asset base, initial caching may take from a few hours to a full day. Once it’s finished, all search and navigation functions will work at maximum speed.
If you ever need to clear cached paths, use the Clear Cache function.Use Ctrl+F to focus the Search textbox, and Ctrl+Shift+F to focus the Filter textbox.
Color Labels: Organize Your Library with Ease
You can now assign color labels to any asset, making your library even more visually organized.
Use labels to indicate status (like “ready”, “in review”, or “draft”), asset type, or even who is responsible for it.
Thanks to the new ability to filter by color, you can instantly find relevant groups of assets in large collections.This is especially useful for teamwork or when managing large archives, where it’s important to quickly see asset status or purpose.
TIPS:
Color labels work together with other filters, so you can combine color filtering with search by name, category, or path
Flexible Folder Hiding in the Library
You now have even greater control over your library’s structure.
Folders can be hidden not just by name, but by their full path in the directory tree.
This is particularly useful if you have several folders with the same name in different locations—such as system or service folders that need to be hidden only in certain sections.Simply choose which specific folder to hide depending on its parent directory.
This allows you to customize your library’s appearance precisely, without disrupting structure or hiding important data elsewhere.
Cleaner, More Functional Interface
The workspace is now lighter and more adaptive.
The bottom panel with general asset information can be fully collapsed, freeing up space for working with the scene or viewing more assets at once.
Interface issues on HiDPI displays with high pixel density and non-standard scaling have been fixed.In the Materials tab, the preview gallery and material tree are combined in a single tabbed panel, so you can switch between the visual gallery attached to the active material and the hierarchical tree view.
Since the first version, Project Manager has allowed you to open assets in external programs (Photoshop, VRMesh Viewer, etc.). In this release, the external app list has become much more convenient: it’s accessed directly from the main panel and is configurable separately for each asset type.
The new “Open With…” toolbar button launches the desired app with a single click and opens selected files for editing or viewing.The toolbar has also gained useful shortcuts—Batch Rename and Convert Images—making access to these operations even more convenient.
TIPS:
You can add your own buttons to the toolbar—standard Project Manager functions (available by default in various menus), as well as custom scripts you can write using the Project Manager API.With the new version, you can also disable certain default shortcuts that may interfere with your workflow—for example, if you often make mistakes with them.
This option is available in Customize → Customize Shortcuts → System Shortcuts.
Disable unnecessary shortcuts and keep only those you really need.Tools That Save You Hours
The Advanced Renamer dialog now offers even more flexible file naming tools.
You can automatically transliterate Cyrillic to Latin, making names universal for any OS or workflow.
There’s also a feature to remove diacritic symbols (like ü, ą, č, etc.), helping avoid compatibility issues with different platforms.Another new feature is the ability to set a custom step for automatic file numbering.
Choose any interval for numbering (e.g., 1, 5, 10)—this simplifies organization of large asset sets and helps you follow your own naming standards.Custom Exclude Expression – This new tool makes it easier to exclude unwanted objects when merging.
Project Manager already allows you to exclude hidden/frozen/not renderable objects, not renderable shapes, or objects by class (e.g., cameras, lights, and more).
But now you can write your own custom expression to exclude models by any rules—by name, by missing class, etc.
You can also disable all other filters as needed.
It’s another flexible tool at your disposal!TIPS:
Use the global variable ExcludeFilterNodes to access the array of objects.
For convenience, you can insert an example script with the “Insert Example” button.
Of course, you’re not limited to deletion—other operations can also be performed.
Note: The “Reuse Merged Models” option will be ignored when using a Custom Exclude Expression.Batch Conversion between File Formats – If you use batch conversion, note that the new version significantly improves the stability of converting between different formats—even for thousands of files.
Not only VRSCENE export is supported, but also import.Bonus Content — Evermotion Models
In addition to significant speed improvements and fast search, the new version of Project Manager includes a small, but carefully selected,
collection of 13 high-poly Evermotion models—for both interior and exterior projects.We’ve carefully selected models from various popular Evermotion series:
This collection is a hand-picked selection from recent releases that helps you quickly add realism and style to your scenes.
All included models are optimized for Corona and V-Ray, supported in 3ds Max 2021 and later, include textures, and are ready to use.Note: This is not a full Archmodels catalog, but a specially selected set for introducing and getting started with high-quality Evermotion content.
You’ll find a detailed list of available models right in the Project Manager window.
We plan to further expand the collection and introduce you to new models in future updates.Why Update Right Now?
Time is the most valuable resource in any project.
The new Project Manager lets you find, organize, and manage files at maximum speed, while the updated interface and additional tools make your workflow even more comfortable.Update now and enjoy working—discover the new possibilities today!
$60.00Add to Cart
Search & Filtering Improvements
UI Performance & Stability
Interface Improvements
Mass Rename Tool Enhancements
Batch File Conversion & Tools
3ds Max Integration
3D Models
Miscellaneous
Related to "Project Manager 3.40.00 — Instant Search"
