  • #43546
      Project Manager 3.37.41 - Navigate and Organize 3D Assets - Custom Icons and Quick Access Recent Assets with Project Manager
      The list of updates for the new version of Project Manager may be concise, but it introduces some exciting and convenient features.
      Here are the highlights of this release: customizable Icons for directories, a Recent Assets category to quickly access your last-used assets, and a new “Everywhere” Search Option to streamline searching across all cached data.
      This release focuses on enhancing navigation, improving asset organization, and optimizing database performance.
      Explore all the updates below!
      Recently Used Assets
      Keep your most frequently used assets at hand with the new Recent Assets category, which automatically stores recently imported 3D models, textures, and materials.
      Recent Assets keeps links to the last 25 used assets, significantly simplifying the workflow with frequently used resources.
      In team collaboration, the Recent Assets folder also includes assets used by other team members, providing a shared view of recently utilized resources.
      This ensures better coordination and quick access to assets across the team.
      This feature helps you stay focused on key tasks and avoids wasting time searching for necessary files.
      Project Manager 3.37.41 - Recently Used Assets
      Organizing Your Library
      Assign Icons to Directories
      Now you can easily organize your library by assigning custom icons to directories. Use built-in icons or add your own fonts (e.g., Font Awesome) and SVG files for unique directory icons.
      Along with the ability to assign colors, this makes navigation more convenient and visually intuitive. Icons can be used locally or synchronized for team collaboration:
      • Local Use: Icons remain accessible only on your workstation, ideal for personal projects.
      • Team Collaboration: Configured icons can be synchronized for shared access via the team database. This ensures all team members use the same settings, simplifying collaboration.
      Assign Custom Icons
      Additional features include:
      • Searchable Icons: Easily find icons by name using the search bar.
      • Most Used Icons: Frequently used icons are automatically categorized under “Most Used” for quick access.
      • Category-Based Deletion: Manage and delete icons by category for better organization.
      • Pinned Settings Dialog: The dialog for assigning colors and icons can now be pinned, allowing it to stay open until manually closed for more convenient adjustments.
      These settings are available in the Tree Settings panel and can be adjusted at any time.
      Include to Catalog
      Using Сatalogs, analogs to virtual folders, you can organize your directories without physically moving or duplicating them on disk.
      You can add a directory to a catalog by dragging it into the desired catalog or using the Copy/Paste function.
      However, this requires locating the target catalog in the folder tree.
      The new “Include to Catalog” menu item simplifies the organization of your directories by allowing you to add them directly to catalogs from the context menu.
      This eliminates the need to search for the desired catalog in the folder tree, making the process faster and more efficient.
      Project Manager - Include to Catalog directly from context menu
      Improved Search Performance
      With caching optimizations and a new “Everywhere” search option, users can find the resources they need almost instantly, even in large databases.
      This is useful for large libraries with thousands of objects.
      Search “Everywhere”
      The “Everywhere” search option allows you to locate assets across all cached data. This nearly instant search feature saves significant time when finding any asset.
      To use this feature, your data must be cached in the database.
      Enable the
      Assets Cache option in the Preferences dialog. Depending on your data volume, the caching process may take some time.
      Search Query History
      View and reuse your previous search queries with the new Recent Search Terms menu. This is convenient for repetitive searches and saves time.
      Project Manager - Search Everywhere & Recent search terms
      Database Updates
      • Support for the latest versions of MySQL (9.1.0) and MariaDB (11.6.2).
      • Performance optimizations for MySQL and MariaDB databases to ensure faster and more stable operation.
      Important Information:
       – If your database contains a large volume of data, the update may take additional time (5 minutes or more).
       – MariaDB users are recommended to update to version 11.6.2 to ensure compatibility and access to all enhancements.
      Bug Fixes and Improvements
      • Fixed an issue with caching assets in teamwork mode.
      • Resolved minor issues when using MariaDB.
      • Made small interface changes and fixed some bugs.
      • General optimizations for improved performance and usability.
      The new features and improvements in Project Manager are designed to optimize your workflow, boost productivity, and provide maximum comfort while working.
      Thank you for choosing us! Your feedback helps us improve the product.
      • Adds the ability to assign icons to directories
      • Adds the ability to add custom fonts and SVG files to the library
      • Introduces a new category: Recent Assets, which stores recently merged 3D models, textures, and materials
      • New menu item "Include to Catalog" makes it easier to add selected directories to catalogs from the context menu
      • Adds a new search option, "Everywhere", enabling searches across all cached assets (requires the Assets Cache option to be enabled)
      • Displays recent search terms in the Search menu
      • Discontinues support for the light theme
      • Adds compatibility with the latest versions of MySQL (9.1.0) and MariaDB (11.6.2)
      • Includes optimizations and improvements for MySQL/MariaDB databases
      • Fixes an issue with asset caching in teamwork mode
      • Resolves minor issues with MariaDB servers
      • Some interface changes and bug fixes
      • Some additional optimizations and improvements
      • Important: Please upgrade to MariaDB 11.6.2 if you are using a version earlier than 11.6
      Related to "Project Manager 3.37.41: Custom Icons and Quick Access Recent Assets"
