  • #42754
    Nikola Merazzi
      Hi!
      I have a folder with max and previews files with same name.
      and in another directory a folder with subfolders named as the correspondent max files with their maps.
      Question:
      Can I relink by name? I mean, use Batch Relink to search maps in folders with same name of the max files?
      It will avoid relink wrong maps.
      Thanks!
  • #42758
      Using the last version, you can use the option “Search Directories Filter” with filter <filename>
      This allows you to search textures in directories with the same name as 3ds max file.
      The advantage will be given to folders with the same name as the 3Ds Max file.
      1. Add files/directories with 3ds max files
      2. Add directory or several to search textures
      3. Turn on the “Relocate Links” option (optionally – use if previously you relink textures to incorrect path)
      4. Open the dialog “Search Directories Filters”
      5. Switch to “Include” and add <filename> to the list
      6. Hit START button
    • #42760
      Nikola Merazzi
        AWESOME!!! You saved me thousand of hours!
        I will try that!
        And In case the maps files are in the same max folders or subfolders?
        How to batch Relink can locate the correct files?
        Thanks, again!
