  • #14807
      • Now asset files refreshes automatically after changing link to xRefs
      • Speeds up resolve, strip and change the links to asset files
      • Now .ifl files are copied properly when user collect asset files or make an archive
      • Supports only to x64-bit system
      • Fixes a bug in FStorm Render when 3Ds Max crashed on trying to access Bitmap FStorm properties
      • Fixes a minor issue with renaming asset links
      • Fixes a minor issue with removing some links from scene ( menu-item “Remove Link From Scene” )
      • Fixes an issue with very slow relinking of materials in Corona 1.7
      • Fixes an issue with renaming external files with status #Found on HDD using the “Specify Asset Path” dialog
      • Fixes an issue with using a full and demo version of different Kstudio’s plugins at same time
      • Fixes a compatibility with plugins which use a old version of NLog library
      • Fixes a bug when in some situations window not drawn properly
      • Fixes the issue with opening VrMat files with #Found status
      • Fixes the bug with crashing the 3Ds Max when user try remove some links from scene
      • Fixes the rare bug what can occurs on closing the plugin
      • Fixes some minor issues for scenes with xRef files
      • Other some changes and speed improvements
      Original price was: $19.50.Current price is: $14.63.Add to Cart
