  • #35788
    Thomas C
    Threads: 45
      Hi Alex,
      I have the following issue:
      _ I browse a folder containing 3d models preview (.jpg format)
      _ I activate the “View image (Space)” feature to see a bigger image
      _ one of the enlarged view doesn’t match the correct preview
      I recorded a video where you clearly see the issue: https://web.tresorit.com/l/fM3n2#U9sng_KF5mxDEvJ8XeaYMw
      When I select “VOL_195___DRINKS_COC_05.jpg” file, the bigger image displayed is not “VOL_195___DRINKS_COC_05.jpg”, but “VOL_195___DRINKS_COC_03.jpg” instead (although the name of the file correctly shows “VOL_195___DRINKS_COC_05.jpg”).
      I tried refreshing the folder but the issue remains.
      Thank you for your support Alex, much appreciated.
    Plugin version: 3.18.24
    3ds Max version: 2022.3.3
    Renderer: Corona 8 Hotfix 1
  • #35791
    Threads: 1217
      Just remove the wrong preview from the gallery
      Currently, the original preview is replaced by other
  • #35792
    Thomas C
    Threads: 45
      Fantastic!
      Thanks a lot Alex  :)
