Viewing 5 posts
  • #18059
    Adan Martin
      Hi.
      I don´t know if i´m doing something wrong or missing some options here but if i save a single model from a complex scene using the save/export selected icon and i try to manage asset files i get ALL the maps from the scene instead of just the ones from the selected model. To solve this i need to re-open the file and save/export selected again in order to remove additional maps. This consumes a lot of time. Is there a way to improve this?.
      Best!
  • #18061
      Hi.
      This issue is solved in version 2.95.03.
      Since version 2.95 Project Manager clears the scene from unused assets before saving a single model. ( This feature works with 3ds max 2015 and above.)
      If you are use the latest version and this doesn’t work for you please generate the bug report and send one from your scenes to support@3d-kstudio.com.
      You can generate the support request using the menu “Project Manager” ==>> Create support Request.
  • #18065
      You’re right.
      My tricks sometimes doesn’t work and “save selection” works just like a default 3ds Max function – so models saved to separate file with all assets from parent scene.
      Will try to find other solution.
  • #18076
      Please try version v.2.95.30
      You can download it from dashboard.
      Auto-updater will be triggered in few days if there’s no critical issue found.
  • #18086
    Adan Martin
      Hi! Thanks for your reply.
      It´s working like a charm :O. Thanks a lot you save me lots of work ;)
Viewing 5 posts
