- February 19, 2018 at 18:07 #14814
TORRI
ParticipantPosts: 1Threads: 1Joined: Jul 2014“Project Maneger 2.88.06″
does not work ! after last update.When I open the program I receive the message:
–UnKnown property: “GetMaxFleFullPath * in undefined
in maxscript Listener this script:
“- Error occurred in GetDependentFiles(); filename: C:\Users\masi\AppData\Local\Autodesk\3dsMax\2015 – 64bit\ENU\scripts\TrackScripts\ProjectManager\AssetFunctions.mse; position: 3612; line: 61
— Defined in encrypted script
— called in GetDependentFiles(); filename: C:\Users\masi\AppData\Local\Autodesk\3dsMax\2015 – 64bit\ENU\scripts\TrackScripts\ProjectManager\Assets.mse; position: 1575; line: 31
— called in ntEiRKl4EtVRBV4Oy+4uate7YtYv3xIuaBTEWmjXMi0=(); filename: C:\Users\masi\AppData\Local\Autodesk\3dsMax\2015 – 64bit\ENU\scripts\TrackScripts\ProjectManager\Assets.mse; position: 7684; line: 122
>> MAXScript dotNet event handler Exception:
— Unknown property: “GetMaxFileFullPath” in undefined <<“”Plugin version: 2.88.06
3ds Max version: 3d studio max 2015
Renderer: Vray 3.60.4 - February 19, 2018 at 18:09 #14815
ModeratorPosts: 263Threads: 1238Joined: Aug 2009Completely uninstall the Project Manager and install again.
Please use version downloaded from 3d-kstudio.
- February 20, 2018 at 19:37 #14829
TORRI
ParticipantPosts: 1Threads: 1Joined: Jul 2014Problem solved.
The plugin is fantastic. I could not work without this plugin.
Thanks for your constant work - February 21, 2018 at 17:47 #14839
ModeratorPosts: 263Threads: 1238Joined: Aug 2009Thanks for your feedback, Torri!
