  • #43145
    Vjekoslav Kiraly
      Hi, when I have a new scene, and I drag a few objects in, and want to link the textures, Project manager is always asking to save the 3ds max file before doing that. When I was on File Path finder pro previously, I didn’t have that message. Is it possible to turn off that pop-up window?
    Plugin version: 3.36.41
    3ds Max version: 2024
    Renderer: FStorm/Corona
  • #43147
    Threads: 1276
      Hi
      You should save a file before relinking
  • #43148
    Vjekoslav Kiraly
      Thanks, however while using Pathfinder Pro, I never had to do that, so there’s no way on turning that off?
      Because I have a “scrap” max instance, where I import all models, clean them, then transfer to an actual scene. With this I always need to save these scrap max files
    • #43156
      Threads: 1276
        I will check for this. In some cases, it might be possible without saving current scene
