Tagged: Materials, Pivot, Project Manager, Project Manager - Update History, Project Manager version 3, Render, Thumbnail
- March 23, 2021 at 17:50 #31521
- Adds support to 3Ds Max 2022
- Adds an ability to add materials to templates using drag&drop [Add template Material(s) function]
- Adds an ability to paint over xRef objects
- Speeds up merging 3d models
- Speeds up merging 3d models as xRef
- Fixes a bug that occurs in some scenes on opening Asset Files tab
- Fixes some issues with applying textures
- Fixes an issue with fit a proxy to viewport on rendering preview
- Fixes an issue with removing atmospherics on rendering previews
- Fixes other some minor issues
- Updates the API example script "PostMerge-ConvertMaterials.ms"
The new version gains support to 3Ds Max 2022.
Setup pivot point on Rendering Preview for 3D Models.
Add Materials to Templates using drag&drop.
Other speed and optimization improvementsRendering Preview
Project Manager has the ability to batch render previews for asset files. Most 3d file formats, such as max, 3ds, fbx, vrmesh, abc, cgeo, and many more are supported.
This version gains the ability to override models pivot point when rendering previewsAlso, is fixed a problem with the placement of some proxies in the viewport. Now the preview for the proxy is rendered correctly, without clipping.
Custom Material Templates
Since version 2.8 Project Manager has the ability to create the material templates with desired settings – for example, reflection, glossiness, and set the texture type with desired default parameters.
This version allows users to add materials to the template using drag&drop. So now you can prepare templates using Slate Material Editor.You can see the full list of changes and fixes below.
Related to "Project Manager version 3.14.15"
